Dead Force 85
jfnewell1965
Howdy,<br /><br />I have a 1985 Force 85. Rebuilt 4 years ago by previous owner.<br /><br />120 PSI in Cyl #1<br />100 PSI in Cyl #2<br />0 PSI in Cyl #3<br /><br />Water on all three spark plugs.<br /><br />Had a sneaky feeling it was over heating. Checked impeller, it is good. Checked thermostat, it is good. Forced hose water down hole where thermostat goes, and that makes water leak out around the head of the bolts for exhaust manifold.<br /><br />Oddly, the thing starts incredibly easy.<br /><br />Feeling a bit low. Any one have light for the end of my tunnel?<br /><br />Jim
novicetech
Re: Dead Force 85
Time to pull the head, and pray it is just the gasket.
roscoe
Re: Dead Force 85
"Any one have light for the end of my tunnel?"<br /><br />I hope it is a cheap and easy fix.<br />Has this motor been run in saltwater?
pigster30
Re: Dead Force 85
I have a Force 120, had water in the bottom 2 cylinders. Pulled the head off and replaced the gasket, that didn't seem to help. I eventually pulled the engine out and removed the exhuast manifold, low and behold that gasket was shot to hell and back. Sounds like the water is getting into your cylinders thru the exhuast. I would pull the head off as well and replace that gasket as well. YOu can get both gaskets on line for about $40 apiece at the mercruiser web site.
jfnewell1965
Re: Dead Force 85
Originally posted by roscoe:<br /> Has this motor been run in saltwater?
It has been run in saltwater in the past, but I personally have only had it in fresh.
jfnewell1965
Re: Dead Force 85
Originally posted by pigster30:<br /> low and behold that gasket was shot to hell and back. Sounds like the water is getting into your cylinders thru the exhuast.
I thought since water leaked around the bolt on the exhaust, that this might be so, but does that account for the low (non-exsistant) compression on #3 ?
