Hi All. Still working on my 1978 115 rude.Starboard side top and bottom cylinders running perfect. Port side not hitting. At about 2600 rpm on muffs the lower port cyl. will try to "wake up". But nothing from the other one. Afraid to rev much higher out of the water. Will it hurt it? Have very good spark, will jump the length of the boot, is blue with a loud snap. Pulled carbs, it has 2 two barrels that each side shares. cleaned all jets and replaced with new gaskets but still won't run right. It seems odd that one side runs good and the other side doesn't with common carbs. Did pull the port side plugs while motor running and they are dry.Changed power pack and both coils to no avail. Took plugs out of star. side and installed in port. No help. If you guys can't help, it's a trip to the shop that I can't afford. Thanx for any help. tgh3fan
