Re: Dead Rise
Banzaib,<br /><br />Don't let anyone take the deadrise out of you! There's a lot of misinformation on this deadrise thingummy. <br /><br />Nearly all quoted deadrise figures are for transom deadrise only. Deadrise is a variable, which changes foot by foot as you go forward from the stern, so quoting one figure alone doesn't give you even half the story.<br /><br />The pointy bit up front that plows a furrow through the water is just as important, because this meets the water first, but you'se b'aint be seein many quoted figures on that. Then there's the bit in between front and back - commonly called the hull. The deadrise along the hull varies depending where you measure it.<br /><br />So although some people quote deadrise as the ultimate measure of performance,it b'aint. It's just one of a pile of numbers that make up hull design.
