I’m splitting this question out of my main thread because it’s a problem I’ve not seen written about, and may deserve special attention.
My main rebuild thread is here: https://forums.iboats.com/forum/eng...ds/10527841-tagged’s-140-johnson-resurrection
After replacing the #1 ignition coil, I still didn’t have spark. Using a gap-style spark tester, I determined that I had no spark, zero, if I connected the tester between the HT lead and the head of the spark plug, where the HT lead would normally connect.
But it if I connect the tester between the HT lead and the base of the spark plug, where you put a wrench on the plug, it would jump a spark across a 1/2” gap.
Does that mean mean the plug is bad? I’ve never heard of that happening. I didn’t have a plug wrench with me to check if it was simply fouled.
Ideas?
Ideas?
