dealer pulled thermostats - whats with gudgeon
scottoz
Hi all. I noticed that Rodbolt in another post noted that thermostats are used as part of the pressure control system. I have a 93 115 V4 Yammy. A merc dealer recently serviced it and put in a new water pump including seals. He took out the thermostats and said that they were gummed up (they were only 1.5 years old). He said that in our climate (winter is rarely less than 2-3 degrees centegrade (water dont freeze in my part of town) we dont need them. The engine runs beautifully and is pumping heaps of water out of the exhaust and out of **** tale at idle. I have noticed that the engine gets slightly hotter in one bank than the other - is that normal? Both can be touched with hand staying on them without being burned or having to move hand away. What do you guys think about the thermostats being removed in warm climates - I always idle the motor to warm before getting under way under throttle and up onto the plane.<br /><br />Also - I have the motor on a 21' Seafarer cruiser (f'glass deep V 21 degrees- from 70's)- about 1700 kilos with people and gear on board. It gets on the plane nicely without anywhere near full throttle and holds it well. It cruises nicely at 4000rpm at 25 miles per hour and if I wind it out it will do 39 miles an hour at 5500 rpm. I was wondering if the yammie (low hours - about 400) would be happy to run at 5000-5500 all day. I had heard of some gudgeon pin problems with some of the earlier yammy's.<br /><br />Thanks mate :rolleyes:
Silvertip
Re: dealer pulled thermostats - whats with gudgeon
Thermostats are not only pressure control devices, they are temperature control devices that maintain engine temperature at optimum levels regardless what part of the world you live in. Too cool they varnish up which cause problems with stuck rings, carbon build up etc. If the manufacturers didn't feel they were necessary they wouldn't be in virtually every engine built today (or yesterday). Put it back in and send the dealer the bill. Then look for a new dealer next time service is required.
noelm
yep what upinsmoke said, what part of Aus you from?
rodbolt
I am with upinsmoke<br /> find another dealer. with no t-stats the pressure contol valve cannot funtion properly, the heads should stay cold though. it may have other problems. 93 yams I think still had the small wristpins. I would not hold it steady past 5K for extended periods. in fact 4 to 45K is a good cruise RPM for extended periods.
scottoz
thanks all - could it wait until next service in 10 months without too many dramas<br /><br />PS. Brisbane Noelm<br /><br />Cheers
noelm
rodbolt would be best to answer that, and Oh Brisbane, coming up next week for the State of Origin and this will mean nothing to anyone in the US but "go the blues"!
scottoz
Its a pitty they closed down the quaratine border gates!
noelm
yes the border gate was a good way to stop the "cane toads" moving down to NSW into "gods own state", what do you do fish, ski, cruise or all those things?
scottoz
Pretty much all of the above buy I prefer fishing and cruising. I have been to Port McQaurie twice fishing - great place.<br /><br />Cheers mate.
