DECARB DFI
Fly Rod
:) When decarboning a Evinrude 2003 225hp DFI Can I spray the deep creep directly into the air intake ports???? Just a little confused!!! :confused: <br /><br />I have the thread "Decarbon your Engine" that roscoe put out but I just wasn't sure if the directions were just for the old 2 stroke system!!!<br /><br />Thanks for any information!!! ;) :cool:
seahorse5
Re: DECARB DFI
When you spray a combustionable mixture into a DFI motor, it will rev up. Your best bet is to back the trailer into the water, or tie the boat securely to a dock, and idle the motor in gear while you spray into the intakes. The load on the motor will keep it from revving up too high.<br /><br />After you soak it, run it at an idle for a while because a solvent like SeaFoam washes a lot of the lubrication out of the crankcase. The factory made Engine Tuner has an oily film to help protect the motor while it is being injected.
