Decarb on muffs safe for RPM's?
RobsTV
Have a '83 175 Evinrude that is trailered to ramp on narrow river that leads to Gulf of Mexico after 40 minutes of no wake zone. Plenty of waterfront homes.
Looks like I need to keep RPM's up during decarb.
Is this safe to do out of the water, on trailer, only using muffs?
That way, it would be easy to let it sit and soak between applications.
Otherwise, would need to go out in the gulf a little ways, and would not want to sit for long between applications, or have starting issues. Can not do it at ramp or dockside.
Also, was originally going to use Seafoam, since I've used it for years in my other stuff, but a couple people have told me that with this motor I should use OMC stuff that comes in a can and screws directly into a schrader type valve on starboard side of engine. Will that make a difference as to where and how I perform the decarb procedure?
What would you do?
Thanks.
tashasdaddy
Re: Decarb on muffs safe for RPM's?
not really, but don't exceed 1500 rpms on muffs, can cause runaway any higher.
RobsTV
So it is not really safe to do because I should not exceed 1500 rpm's on muffs?
darrklim2
I think when Tashasdaddy said "not really", the response was to your question of "Will that make a difference as to where and how I perform the decarb procedure?"
Therefore I think it is ok to do the decarb procedure with the muffs but don't exceed 1500 rpms.
tashasdaddy
yes it will be worth it. the main object is the bring the motor to operating temperature. then use the schrader valve. whether the motor is running 1500 or 2500 the tstat is only going to let it get so warm.
RobsTV
Thanks for the help, that was what i needed to know.
