da_ardvark
- Joined
- Jul 31, 2007
- 39
Ok, I did a compression test on my 1985 70 HP Johnson.
Top Cylinder was 105 psi
Middle Cylinder was 105 psi
Bottom Cylinder was just shy of 105 psi
All the plugs looked good. Tan in color and oily around the edges. No oily residue on either sides of the electrodes.
I read the Decarb FAQ and I want to know a coupla things. Can I just use my extra fuel tank to mix up the 3/4 gal to 1 pint of seafoam?
Should I run seafoam thru before I spray seafoam into the carbs and cylinders?
What kind of compression increase can I expect under best case scenerio?
I'm going out next week with family and I want to make sure (as much as possible) that the engine is going to perform well.
A little background. I just bought the boat and engine, and have had it out twice. Each time at WOT the engine cut out (didn't stall but I had to reduce throttle and only happened 3 times the first time out and twice the second) I cleaned out the tanks and the fuel fliter (There is no fuel filter in the VRO pump right??)
Anyway I'm trying to be careful during this process so as not to make matters worse.
On last question. Should I buy ready made plug wires, or can I use auto high performance wires that I cut and make myself.
Thanks
Denny
Thanks
Denny
