Re: Decarb Question
I will decarb all three cylinders and retest the compression. I do need to decarb twice don't I?
My mechanic said that the ignition problem was weak and inconsistent fire on 2 cylinders. I think he meant inconsistent as being sometimes a weak spark and sometimes a good spark causing those surges and cutting outs I was experiencing. What would cause this? Stator, trigger, rectifier, switchbox, coil, combination? He thinks it is the stator but he didn't do an in depth inspection since I just brought it in for a carb cleaning and impellar change. He recomended getting a new ignition system so it would be warrantied. I may get some electrical testing tools and try to figure it out on my own. None of it looks hard to replace just a little tricky to diagnose.
You don't need to do it twice, but it will get more junk out.
He recommends a new ignition for ??? $700-$1200 !!!
Not much of a mechanic if he can't test the ignition components and only replace the bad ones. And I'd really like to see the fine print on that warranty.
Sorry for my bad attitude, but its been a rough day, and I don't feel like sugar coating it.
The stator generates electric current, usually works or doesn't work. Appears to be working.
The trigger is a signaling device, that works with the switchbox, telling it when to fire. Appears to be working.
The rectifier converts ac current from the stator to dc current, used to charge the battery. Working?
Coil, old? fails intermittently when they start to fail? Possibly.
Old degraded sparkplug wires, possibly.
Now this is all without actually testing any of the components, which needs to be done.
I certainly wouldn't agree to let him start throwing $300 parts at the motor, if he can't even test them to see if they need replacing.
Seems strange that you are hesitant to have the bore honed and the rings replaced for a few hundred, but you think he should replace the ignition without knowing what parts are bad.
