Decarb spray or liquid?
nimmor
I have been reading a lot here about decarbing and it sounds like a good ideal, that is also the majority impression I get also. Which is better though the kind you spray or the kind you mix up and run though the gas tank or a milk jug? Is the mix for more detailed work. I have a 1959 35H.P. Johnson that judging by the pistons when I had the head off has never been decarb.
cajun555
Re: Decarb spray or liquid?
I just decarbed 56 30hp last week. I used the tank method. Smoked out the neighborhood. Haven't used the spray method. Some folks swear by it. Both methods do achieve the same results. Different strokes for different folks.
Ronald1
I am planning on doing the "tank" method at the lake. As I understand it I'm supposed to troll around for 15 min then let sit for 15 min and restart. When I restart my motor do I run it on the "cocktail" or switch over to the regular premix? Do I cruise or blast around at wot? What do I look for? I notice that most people are doing this on the muffs. Anything wrong with doing this at the lake. Muffs make me nervous. Thanks
phatmanmike
i think the tank method is better simply cause it cleans all the insides of the carbs and all the fuel hoses at the same time, along with the fuel pump... i run it through the tank, then when i turn motor off i spray it directly in plug holes.....<br /><br />best of both worlds<br /><br />m ikey
