Re: Decarb ValveTech
ValveTect Marine Motor De-Carb states it is for use on all 2 & 4 cycle engines. It is a naptha based cleaner>>>"CONTAINSPetroleum Naptha(8030-30-6),2-butoxy ethanol(111-76-2),9-octadecenoic acid(Z)-,ammonium salt (544-60-5), liquified petroleum propellant(68476-86-8),2-pentanol,4-methyl-(108-11-2)"<<<<<<br />Now as far as how well it works>>>you need to be more of a chemist. I tryed it in my 1991 GMC 5.7L & it seemed ok, I will be using it in my 115hp Johnny before I lay it up for the winter.<br />One thing I found curious, It said to NOT let the engine stall, but to shut it off after spraying the can into the air intake. Then let sit for 15 minutes before resarting. I would have thought it would need a bit more time to soak & to let the engine stall out as to get the combution chamber "wetted" with the cleaner???
