decarb with engine tilted up or down?
crazy charlie
When decarbing through the spark plug holes should i leave the motor up or down as it soaks overnight???Charlie
OBJ
Re: decarb with engine tilted up or down?
Charlie....ya need to run the engine and git it up to norm temp and apply the decarb through the carbs. Then if ya want, tilt the engine up and pull the plugs and squirt some in the holes. Rotate the flywheel some revolutions and let her set as recommended on the tuner can.
crazy charlie
Thanks outboard Jim,I know about running and spraying through the carb.I didnt know if the angle of the motor mattered when doing the second part of the job(through the spark plug holes).I will try with the motor tilted as you suggested.Charlie
AUGIDAWG
I have not done this, so I am talking out my bung hole.<br />If the pistons are down, away from the spark plug hole, and you spray the de-carb in, it will just run out thru the ports.<br />I would, one at a time, rotate the flywheel so the piston is up somewhere before top dead center, and then spray that one cylinder. Wait awhile, do the next and so on.<br />The major carbon will be in the combustion chamber, and around the rings. This method would seem to help the cleaner "wick" around the pistons, and get to the rings better.<br /><br />Spraying the de-carb into the exhaust port, will clean your ehaust pipe. Who cares?<br />Spraying de-carb into intake ports will clean the crank case. It's not dirty!<br /><br />I would suggest turning the steering wheel all the way to one side, raise the engine all of the way, and do this to one bank of cylinders. This way, the tops of the pistons will be at their most horizontal position, so the fluid doesn't have to fight gravity as much.<br />Then, turn the wheel the other way and do the other bank.<br /><br />Now, wait the desired length of time, put the plugs in, and run the **** out of it.
ob
Sounds like AUGIDAWGs got a plan.
BillP
I don't know what brand decarb stuff you are using but OMC Tuner will NOT work cold. Yours may be different. I tried some samples with the OMC and let them soak for days cold, nothing happened. I used cases of the OMC type over the years and know it works with a hot motor if applied through the carbs while running. I do one carb at a time.
