Re: decarb
deep creep does not have the fitting to fit the schrader valve. it has to go thru the intake.
i have neen using this method for years, before the schrader valve. just seafoam, rather than deep creep, they are the same thing, just different packaging.
Decarb, take a can of seafoam put 3/4 of it in the gas tank, with only 1 gallon of premixed gas. put the rest in a spray bottle. start the engine, and let it come up to temperature. then remove plugs, and them some real good shot of seafoam into the cylinders, replace plugs, let sit 15 minutes. restart, and spray the rest of the seafoam into the carbs, so the the motor almost stalls, wait and repeat until the seafoam is gone.then take for a wide open spin. then put in new plugs, ad premixed gas to the tank, and take it for a wide open throttle spin. it is going to smoke like a house on fire, during this process.
