Fly Rod
- Joined
- Oct 31, 2002
- 2,622
Well, I have read alot of articles on iboats about decarboning outboards!!! Even tho I use carbon guard I have been decarboning my motor with Sea Foam!!! In the past I would only do it once giving it a good soaking etc: and waiting 8-10 hrs. following some directions!!!<br /><br />This week end I decided to decarb and started on Friday 8:00Am and ended doing it today, Monday!!! Friday started out spraying 2 cans into the intakes, followed by removing the plugs and using another can in the six plug holes, sat over nite and blew out the carbon early the next morning!!! after seeing all the black crap on the surface of the water, I decided to do the plug holes once again, used another can in the holes, waited till Sunday morning, kick her over and more black crap came to the surface!!! Well thought it over and decided to do it again, went thru the process all over again and kicked it over again today and there was no black crap on the water surface!!!!<br /><br />So my point is that if you decarb you may want to do it at least a couple of times during the process instead of once!!!!
