I have a 2000 Larson 254 Cabrio with a molded in step that goes down to the cuddy.
The problem I have always had was that the drain never worked correctly, there was always water in it- here's why:
Now I went out and cut the rise out of the hose:
However I am now realizing that the rise was there to avoid any raw water from going backward into the step area when the boat rocks and rolls.
Bottom line is, I need this resolved!
Here is another photo which will lead me to my next idea:
I am thinking of installing a small watertight box (Sump) below the step and direct the water into it, install a small 360 gph bilge pump with float and check valve to pump the water out of the original 1.5" thru hull (will have to bush this down to 1/2" or so).
The other idea I had was to install a straight fitting in the step and direct the hose under the rear cabin and into the rear bilge area to let the pumps back there deal with it as needed. The issue I have is dirt, and trash perhaps would migrate back to the rear bilge and clog pumps and make a mess- here is a shot of fuel tank which is under the cabin floor, I can easily run a hose on top of the tank.
The last idea I had was to direct the water to the forward bilge (as seen in anove photo). This already has a pump, I just worry about the debris issue again and the fact that it is a really small area. My thought is that I want to keep the bilge as dry as possible, this would not acomplish that.
Any thoughts would be great, thanks!
