Pake
- Joined
- Apr 29, 2008
- 26
I know there are other (similiar) posts here but I hope you'll let this cadet ask anyways.
I have a 1980 Chaparral 194 boat. The deck was spongy in some places. I was gonna sell it but decided (after reading posts here and seeing YouTube videos) to try to tackle this project.
Well, the deck is wet and rotted, there is rot in the two stringers, standing water in the foam area and termites. I started ripping all the deck off tonight and will get more info/photos then.
Here are my questions. Please answer as detailed as possible as I'm a newb and need all the help I can get.
1. The two stringers are 1" thick pine. Assuming I can get 1" pine in 19' (boat length) lengths, should I use that? If not, what should I use? If plywood, what type? How do I laminate them? Or, should I buy preformed ones? If so, where can I find them?
2. How are these stringers attached to the bottom as well as transom? Is there a particular caulking/epoxy? Do's and dont's?
3. The deck is 1/2" plywood with what appears to be 3/16" thick fiberglass. Should I go with a thicker plywood and thinner fiberglass?
4. Where do I get replacement foam? Some posts I've read suggest a spray in type.
Thanks for the help. Hopefully, with all your help, I'll have her "ship shape" before summer!
