Re: Decking a boat
You're way wrong on this one dude......and even if your weren't, there is no need to be rude to another member when disagreeing.
Im not trying to be rude.. just explaining what foam will or will not do.
I am right on this one ( no need to call me Dude then tell me not to be rude in one sentence .. kinda rude )..
I can build a 500 lb flat bottom boat and it will take WAY more then 500 lbs in water ( 63 gallons of freash water to displacement) to sink it.
"I have a aluminum 15' boat it looks like it used to be decked, if I redeck it can I put some kind of foam to help stabalize or offset the weight of the wooden decking it would be approx 1 1/2 inch or so would that be enough to help and do I leave the drain galleys open or let the water go on top? I appreciate any and all help as always "
The boat does not know if there is foam.. so It wont work unless your counting on balist from the foam ( nobody wants to say that ? ).
" Anything you put inside the boat, including foam, is just weight. The boat floats because of the water it displaces, or pushes aside. If the boat weighs 500 pounds it has to push 500 pounds of water aside. If a boat weighs 500 pounds and has 20 pounds of foam inside, then it has to push 520 pounds of water aside. Foam only hellps if the boat sinks. "
I really dont understand this.. and kinda missleading.. Of Coarse the Wieght of the boat and all components measure some weight.. and the hull volume of displacement is NOT the same from boat to boat ( I dont care if the hull is 500 Lbs .. its the Displacement ( not the entire boat weight ).
Did not mean to be Rude..
But I know I am on many points...
YD.
All I was saying i
