Decking tearout & replace, 96 Klamath
Steve079
My Klamath originally had carpet on the decking, previous owner glued vinyl on top. The decking has several soft spots, so I'm planning on doing the demo & replace. The gas tank is in the bow, so I'm curious what's under the existing decking, and how it's fastened. In a house that would be the joists, I'm not sure of the terminology for a boat. Not sure I'll be able to see the fasteners once the old floor covering. Aluminum hull. Thank you
MikeSchinlaub
Under the floor are supports running length wise along the boat. Those are called stringers. The spaces in between will be filled with floatation foam. Is this an aluminum or fiberglass boat?
