Re: deep cell
Hi Guys just thought I'd add my 2c here as well.
Ah (amp hour) ratings on deep cycle batteries are most commonly based upon a 20hr rate. So in your case, the 140Ah battery can sustain 7amps for 20hrs before it is completely discharged.
Maximum continuous output = Ah rating divided by hours of discharge (140 / 20) = 7amps.
This doesn't translate evenly to other disharge rates. The lower your current draw the more amp hours you will get from the battery. On the other hand, the higher your current draw the fewer amp hours you will get from the battery.
i.e. 140ah @ 7amps for 20hrs doesn't translate into 140amps for 1 hour as you might think. You'd be lucky to get 30 minutes at that rate. And with only a 1amp draw you will get a higher rating; possibly as many as 200 hours with the 1 amp draw.
HTH, I didn't want to get TOO long winded in my response.
