Deep creep???
bellybuster
Where can I get it? I have been to 5 places and I found the Sea Foam but not the Deep Creep. If I put Sea Foam in a spray bottle will it work just as good?
eurolarva
Re: Deep creep???
The NAPAs in Minnesota have it. See if your local NAPA can order it in for you. I doubt a spray bottle will work. Not enough power and you need the straw on the sprayer to get it deep enough into the cylinders. Mercury sells a product called power tune that does the same thing.
bellybuster
Re: Deep creep???
Thanks! I will try NAPA.or buy the power tune!!! Thanks! Bellybuster!
monkeyboi
Re: Deep creep???
belly,<br /><br />you could try advance auto parts of autozone if you have them in PA. both places stock deep creep here in TN.
