This one's a real kick in the head!
Pulll the coil wire, stick the carb fuel supply line in a jug and crank the engine, fuel pumps perfectly.
Using a test tank and primer bulb directly to the carb, re-arm the ignition, prime the carb, add water and stir. Engine starts and runs perfectly as long as your arm lasts squeezing the primer bulb.
Meanwhile the fuel pump gives one squirt as the engine first fires up then no more fuel till you shut off the engine and as the engine makes that final turn to a halt the fuel pump gives up one more shot.
MUST be a defective fuel pump, order up a new one and bolt it on.
And it does the same thing.
Check the rod, cam lobe, all the fuel lines, filters,etc.
Almost 1 inch of stroke, the rod looks perfect, slight burnishing of the ends where it contact, bore in the block feels smooth, bore measures .502, rod measures .499, feels perfect and absolutely falls out of the bore on it's own.
New pump spring tension feels good and stiff, but so does the old one, which is NOT the original, been changed once prior to my assuming maint on this boat. 96 Merc Tournament Ski aka 5.7LX
Ordered another pump, and hoping it was a defective new part.
Also taking my bathroom scale to work Monday so I can rig/have some means of measuring spring tension on these pumps.
This one has ME baffled, (and I am one of the best!)
