confused: the ring around my stock prop on my 1988 88hp evinrude is gone. I believe it is called the defuser, i am not sure what its purpose is. the motor starts and runs good but seems to flutter a little between 3800 and 4200 rpm. the prop is a 12.34 by 21. after 4200 it smooths out and tops at 5700. compression is between 125 and 140 and plugs are clean and not fouled. i have been thru the carbs, timing and synchronization. thanks, keykev...............
