Re: Deleting The Deleted
Bart, Boy have you opened up a can of worms! If you need to really toast files from your HD, Windows delete file function won't get it. Programs like PGP's file deletion utility works well by marking the file space as deleted and then overwrites the file area to Mil specs.<br />As for cleaning the HD of previous program files, it's best to lay the groundwork before you install the program in the first place. Utilities that record all installation procedures and files written for a particular program and then save this 'log' file to your HD. To remove, you run the utility and call up the log file of the original install. It then backtracks the install removing all of the components in reverse order.<br /><br />Registry cleaners that compare program installed paths and verify that the programs are still installed can be used to find those pesky program links and fragments in the registry. Utilities that examine the dll files and link them to existing programs can be run too. Dll files that are left over from old program installs can then be deleted. <br /><br />Of course after all of this work, you should do a defrag and free space overwrite of the HD. It goes without saying that Fdisking the HD and doing a reformat goes without saying as a last resort solution too. This is good enough to keep the casual snooper from getting data from your HD. More drastic measures would need to be taken to really protect the deleted data from a high tech forensics lab. I personally prefer PGP's solutions version 6.58CKT for email and file encryption. Another thread point to the fact that Microsoft snoops on you too. Windows OS's are notorious for keeping data on past file downloads and records email content as well, even after you think it's gone, but that's still another can of worms. Hope this helps.
