So I just rebuilt my demon 500 cfm for my 2010 Volvo penta 3.0L and it actually went really well first try. Problem is the rebuild kit came with a 30CC accelerator pump and the stock one was a 50CC. I've got the lever arm adjusted so that the 30CC works fine (e.g. moved the cam up to the closest of the 3 holes).
Question is... obviously there was a reason that it came from the factory with the 50cc. Is there going to be any serious issues with running the 30cc? if so I think the 50cc that I removed is still fine. It doesn't look torn or cracked at all (but symptoms of the reason for the rebuild pointed at the accel pump but could have been something completely different)
Also, Volvo freaking painted over the sight glass on the bowl (among everythign else) to adjust the float , aside from scrapping paint until I can see is there another trick to adjusting the float? its 99% there but the accel pump doesn't shoot gas for the first 10-15% of travel which I think is attributed to the gas level in the bowl being slightly too low.
Any suggestions would be great.
