Re: Dentonation (89 Evinrude 90 HP VRO)
Damage like that is usually from an ignition source. It may be a bit hard to find if the motor isnt able to run now. If it still runs, you might degree the flywheel and hook a timing light to #3. Run it on the trailer under a load back it down the ramp) and see if that cylinder is double firing or advanced too far. <br /><br />Mark each cylinder at TDC, total timing and its number. When running you should see only the 3 with the light. If it starts picking up another number, its double firing.<br /><br />A bit involved -- I was hoping it'd be easier to find, like the wrong plugs. Those should be OK, especially if you were using them before. I still opt for the QL77JC4's.
