Re: Deposit on Whaler- Advice during sea trial?
Michael,<br /><br />I haven't ever quite seen a T-top mounted only to the console, but I wouldn't think this to be the best of ideas. I wouldn't let this be a deal breaker, but just be prepared to have some modifications to the top so it can be mounted to the plates in the deck that are there for t-tops. The stress created by the weight of the top can work the console loose over time. The console wasn't made to have structures mounted to it.<br /><br />Nice thing about aluminum construction, it is all custom so just about anything can be done, and it shouldn't be that much but a few hundred dollars to get your supports right on something like this. <br /><br />If the boat has been in the water for a long period of time then it needs to be bottom painted. Bottom paint is two fold, it seals the boat so the gel-coat does not blister and prevents marine growth, but it also hides damage. If the paint is old then you can figure they are not hiding too much, but if it is new just have it inspected. <br /><br />The water in the hull could be quickly checked by taking the boat on a trailer to a truck stop and weighing it. Water in the foam can become quite heavy and is NOT easily removed. It can take months or years depending on the amount in the boat. Though it is very rare that this happens on a properly maintained boat. <br /><br />The obvious places to check for water around the hull are where electronics were mounted on the transom (transducers) or drain tubes. Make sure all the drain tubes are in good condition and none of them are corroded through. You can remove a screw on a transducer mount and check for moisture the next day to see if there is water there. If if it is it may only be in the transom which then you would need to check for transom rot. <br /><br />Don't get scared, these are just all things to check on any boat you are buying. All boats have a history which can be good or bad depending on the previous owners.<br /><br />Tully Mars
