Depth finder Hampton 220
JimJam63
Lawrence 3500 finder in the console is no longer functional. I've only owned the boat for a year, motor replacement so haven't been out much. Anyone have an idea where the transducer is mounted? I've tried nosing around but can't seem to figure it out. Like the idea of replacing with another through hull but given that the hull isn't easily accessible I'm wondering if it wouldn't be easier to do a transom mount. The rear berth has screws around the perimeter, wondering if that whole panel comes off? Any advice is appreciated.
motor replacement
In most cases the transducer are shoot thru hull design, so it would be glued to the hull close to the keel and under the motor. Look on the back of the gauge and see if there is a cable attached, and if there is one, might pull on the cable to see if it was cut off when motor was replaced
