depth finder problems
kwelch
My depth finder runs fine while my 75 hp. motor is turned off, but as soon as I start the boat motor the depth finder goes crazy. When I turn the boat motor off the depth finder starts working correctly again. HELP! HELP!
mellowyellow
Re: depth finder problems
interference from ignition?<br />run power wire directly to battery and try it<br />with the motor on. was this on the muffs or<br />underway? prop wash can interfere with transducer<br />reception too. where's it mounted?<br />good luck,<br />M.Y.
kwelch
the depth finder worked fine for the first 3 years when I would run the boat but it recently started acting up whenever I started the motor?
roscoe
My guess is fluctuating voltage while engine is running. rectifier/regulator problem?
remmer38
You need to remove the accesories from your main battery or rebus it. Your motor is hcarging your battery. Putting electronics in a charging circuit is dangerous ( no more elctronics ) and will cause premature failure. Its safe to have several batterys on any size boat where a battery is required. Redundancy. I use a trolling motor battery for my electrics and have a small trickle charger inline. Blah Blah I know but if you have starting problems, another battery is piece of mind. <br />Capt E
