Re: Depth sounder - Transducer mount
Alaskaskiff:<br /><br />You're right about welding brackets to the transom for transducers, but I don't recommending welding aluminum any more than you have to... welding seriously weakens the structure within a couple inches of the weld, so much so design codes require reducing max. allowable stress within that range. A little welding is OK, but it can cause problems for DIYer's if they don't watch what they're doing.<br /><br />ajp:<br /><br />I've got a thru hull up front, where I want my transducer... Better to know what you are going over before you actually end up on it, if only when going slow. It works flawlessly.<br /><br />Installed with 3M 5200, the old transducer will get drilled out and replaced when the time comes... if it comes... it's been holding up for years!<br /><br />As a safety precaution, I installed a device of my own design to plug a leak: Since the transducer is under the bunks in the forward cabin (wasted space), I installed a 4" pvc pipe over the transducer inside the hull. The pipe is long enough to be as much above waterline as possible. I glued the pipe to a standard pvc toilet flange using pvc primer/glue, and using 5200, glued the assembly upside down to the hull inside the boat, using the toilet flange to get a copious amont of 5200 between the assembly and the boat. A glance in the inspection port I cut into the bunk always reveals (so far) a dry space, and since the transducer is isolated from the bilge, I know when (if) the transducer is leaking and it's time to go. If it does leak, the pvc pipe will hold back the flood.<br /><br />This set-up has worked for me for years. If you do it, be sure to install the pipe so it is higher than waterline of your boat.
