I'm looking at a project boat that has a good hull, deck, and engine, bad outdrive and vinyl. It's cheap enough that I can afford a new upper and lower, and custom seating and side curtains, and still come in under budget. However, the engine is reportedly a 350 horse 350 and new enough it's not even broken in yet. I suspect it's just too much for an Alpha drive and replacing the blown up lower unit will just result in a newer blown up lower unit before long. I've come up with two possible solutions: a. switch to a Bravo I, b. detune the engine to 300. My suspicion is that the Bravo would be a very, very expensive way to go and would involve substantial changes to the transom. Unless I'm mistaken about the work involved I'd say that route is out. Detuning the engine, however, is a bit less complicated. Throttle limiter, carb restrictor, cam change, etc.
Question is, should I ignore it because I'm being paranoid, or go with choice a or b?
