HISTORY: I put this 94 merc 150efi motor on my 17 mako. It ran great but at high rpm's would suck the primer bulb flat. I'm thinking fuel restriction in the tank; I replaced a few filters and floats and tried to clean the vent and it worked some, but at higher rpm's would suck flat.<br /> This never affected the motor, always started and ran great. <br /><br />PROBLEM: Recently I went to start the motor and it would not start. After about 10min of priming and choking it finally ran for about 10min perfect and then stalled, and would not start back up. I am noticing a humming sound that appears to be coming from the fuel pump in the motor when the key is turned on, if left on it eventually stops, but it still doesn't start and then the pump(sounds like a fuel pump but unsure) starts humming again.<br /><br />please help desperate for answers mini season around the corner <br /><br />fuel-2wks old with stabilizer <br />spark plugs-new<br /><br />HELP
