Determining A Boats Yr. of Mfg.
rz
I have a 15' Rinkerbuilt Tri-hull with a Serial # of: 1556470, and a capacity of 900lbs.<br /><br />Can anyone tell me what year it is? :confused:
MIKE F
Re: Determining A Boats Yr. of Mfg.
The last two digits of the hull ID number are the year, BUT I'm not sure what year that became the rule. I think it was late 70's, early 80's. Yours might be a 1970, then again, maybe not. :D I'm sure someone here knows the answer. Actually looking at yours again, I think that was built before the standard, since the letters for the abbreviation of the company's name aren't included in that ID number.
rz
Thanks, Is there a web site or somewhere that I might find that type of info.? :confused:
shelbydriver
Yep Mike is right. the last two digits. But that came into play I think 1976
Trent
Actually guys its was 1972 and after that required HIN. Look here and see if this helps?<br /><br /> MIC
rz
Thanks for all the help guy's, I went to the "MIC" site which gave me all the contact info. that I needed, so I called the mfg., and it is a 1970. And after that around 1972 they changed the serial # process to "RNK#####".
