Determining RPM
huntin dawg
Is there a way to determine roughly what RPM my motor is running at knowing pitch and WOT speed of my boat?
My little jon boat runs just shy of 17 MPH at WOT with a 7 pitch prop.
The motor is a Mercury 75, 7.5 HP year 1973.
Thanks,
HD
180shabah
Re: Determining RPM
If we added gear ratio and the speed is gps not dash gauge, we could guess, but could still be off several hundred RPM.
You need a tach to know for sure.
steelespike
Re: Determining RPM
A tinytach is about $40 and easy to install.One for your motopr will fit any 2cylinder 2 stroke.Be sure to read all the info at the tinytach site.
huntin dawg
Re: Determining RPM
The gear ratio is 2:1 and the speed is GPS 17 MPH.
The manual says WOT should be 4500 to 5500 RPM.
Just wondering if it could be roughly figured without a tach.
HD
180shabah
Re: Determining RPM
Assuming a slip between 10 and 25 percent, best guess on RPM is 5700-6000+
But again, this is no substitute for an actual tach reading.
trendsetter240
Re: Determining RPM
Roughly 5700 to 6400 is your current RPM. 5700 with 10% slip and 6400 RPM with 20% slip.
(SPEED X RATIO X 1056) / PITCH X ( 1 - (SLIP/100) ) = RPM
