Has any one ever use DEXRON transmission fluid in their lower units? In the manual I have it suggests that if one doesn't have the gear case oil (80-90 weight) you can use dexron transmission fluid as a replacement. If you do use it, is it better for the lower unit, or is it a poor replacement? ( I happen to have several quart bottles from a failed attempt to change my fluid in the truck.) TIA. Dan
