DF 70 impeller direction
sluketic
I have a 2001 Suzuki Df 70 and I replaced the impeller and plate and can not seem to get the pressure I had before I messed with it, the manual says to rotate the shaft clockwise into the impeller housing but looking at the housing it seems it would work better the other way, What I need to know is the book correct or could this be a typo? Do you rotate the shaft clockwise or counter clockwise?
gsyfishy
Re: DF 70 impeller direction
Put it in forward, by pushing down the shift rod, and spin the prop, this should give the direction needed. And clockwise it should go.
James R
No confusion here. As you press the housing down onto the impeller, rotate the drive shaft Clockwise looking from the top.
