I currently have a 1990 Seapro Center console with a 1975 Johnson 115 on the back. The boat is a flats type of boat with a slight v and weighs 1500lbs with out the motor or fuel and gear. It also has a 42 gallon built in fuel tand and there is usually around 30 gal of fuel in it. It has a 20 inch transom with a 15 degree deadrise and it has a step in the transom that is 6 inches up from the bottom of the v, and sets back about 7 inches into unto the bottom stern area of the boat. It is also about 32 inches wide.
I have learned a lot from some of your earlier comments on stepped transoms and I am trying to get mine set up as efficeint as possible without going broke. I currently have my motor in the highest hole which puts the av plate about 1 1/2 inch above the bottom of the boat. I can run about 30-32 mph at WOT and get about 5400 rpm with a four bladed 13 pitch prop. (the four bladed prop has helped it back up much better that the 3) I feel that I need to go higher and am considering getting either a jack plate or a cmc tilt and trim to mount the motor higher. What is the average height for a boat with a stepped transom? How far below the step does the av plate usually ride? Thanks for any help.
