farginicehole
- Joined
- Apr 15, 2003
- 482
Sorry, as I know you've probably talked about this subject until you're blue in the face. I did the search using "block venting" and, for the life of me, can't find the post where you(?) mentioned the OMC part number for the little fitting. Do you have that handy, or is there something I could pick up over at NAPA that would work? I'm assuming it's just a little plastic fitting that I would just drill and tap my water jacket for, and then T into the existing hose to go to my "pee hole"? Thanks in advance for all of your help!
