TwoBallScrewBall
- Joined
- Sep 14, 2003
- 1,695
Hey DH,<br /><br />Thanks again for the help last fall when I bought the 'new' boat. You had mentioned a week or two ago that my RPM/Speed numbers seemed off. I did the math and you're right. <br /><br />I remembered when I first got the boat I got 43mph out of it. My problem was the holeshot, it was horrible. So we chatted and I ended up raising the motor up all the way which greatly improved the holeshot. However I never again got above 38Mph. <br /><br />So over the past couple weeks I've been playing around. Here's what I've found. <br /><br />Holes:<br />1 1<br />2 2<br />3 3<br />4 4<br /><br />14.5X19P Stainless OMC prop. <br /><br />Motor at top height (4 out of 4) - Decent holeshot, top end 38mph, at anywhere from 5200-6000 depending on trim (little or no change in speed with RPM with trim)<br /><br />Motor at Next to Bottom height (3 out of 4) - Horrible holeshot, need to really play with the trim to get it to bounce up on plane, or use trim tabs, even with only 2 people on board. Top end is 43mph on gps, at 5400R. (this was the stock setup)<br /><br />I didn't notice it until I moved the engine back down, but at the top hole, I was getting a lot of slip/ventilation in turns. The boat feels a whole lot more 'solid' or 'footed' with the engine back down. <br /><br />I am going to stick with the current setup, because it gives me a nice 30-32mph cruise at or just below 4000R (as opposed to 27-28mph at the same RPM with the engine up higher). I am considering a modest hydrofoil to see if I can get on plane easier. <br /><br />Motor trim to get on plane is weird. If I start out with the motor trimmed all the way down, the engine hits 3800R and will stay there, nose up, forever. <br /><br />If I go 1/4 up on the trim guage, just about the same thing happens. <br /><br />If I start out there (1/4 up) and when speed maxes out there (but not yet on plane) trim up to 1/2 or a little more, it will dro pdown on plane. <br /><br />If I start out at 1/2 up it planes out but takes forever. And a day.<br /><br />So, what are your thoughts?
