Benny1963
- Joined
- Sep 17, 2006
- 1,476
or anyone with some info on these motors 1983 johnson block ,149 cid 175...
im haveing problems with my thermo cover on one side sealing also head passage cover gasket weeping,the powerhead has been sitting,im running 150 carbs,it has seen some salt but low hour,head cover bolts look like they will break before comeing loose.so i can get some 200 crossflow heads
xp will they work on 149 cid block and will they help power ,over the 175 heads because i may change heads so all have to do is put some fresh gaskets on heads and run them will probaly try to use since there spotless
i also have my 150 crossflow heads 149 cid will they run on the 175
thanks
thanks
