Re: Dhadley, question on your X dimension
Dhadley,<br />My Setup is a Bayliner, hows that. lol. I know but actually I love this obat now. I have redone the interior to the way that I wanted it, Redid the entire floor, with alot of Fiberglass and resin so it will never get soft again, of course replacing the bad wood at the time. Recarpeted it. Redid all the guages and everything and now I love it.<br /><br />The engine is the old Force 125, that seems to be running better than it ever did in the five years I've had it. But I'm meticulous on that engine about fixing it before something does mess up. The last piece I have to get fixed is the Trim Pump it has some stripped threads where the lines go in, so the machine shop is going to drill them out and put some brass fittings in for my lines to go into.<br /><br />Boat is 1988 Bayliner Capri 19 Foot Open Bow<br />Prop- Hustler 13 1/4 X 17 pitch prop -Love this<br />Boeyson Reeds<br />NGK Plugs<br />NGK Screw on Spark Plug Caps<br />Carbs cleaned and synced as good as they can be<br />New Fuel Diaphragm<br /><br />Timing needs to be double checked, but I think its set at 30 or 32, but I just found I think its supposed to be set at 28, what difference woudl this make?<br /><br />Boat will run 5000 RPM's and just over 40mph by Garmin GPS 12<br /><br />I do all the work, its like a hobbie to me. I have a buddies old Merc 115 Inline 6 all torn apart in my garage waiting for the pistons to rebuild that, so we can make his little boat scream. Also have another buddies Crestliner 19 Foot old boat, with a reinforced transom and Johnson 200 in my driveway that we are working on today. This boat will straight fly. But it has no spark, but on one cylinder.<br /><br />Now you see my setup, and what I like to do. I love to fix things, I guess thats why I do tech support for computer company. lol<br /><br />Ill try to get some pics of My boat up here somewhere. How I did the inside, it sure doesn't look like a bayliner, inside anymore.<br /><br />Thanks,<br />Bryan Cox
