Re: dial indicator no spark plug adaptor
tsutter, I don't know what you are trying to establish TDC for on that engine, but if you don't have any other way, just break a insulator out of a spark plug, screw it half way in the hole, with the engine close to TDC, stick a metal rod or bolt in the insulator hole till it touchs the pistion, mark the rod for depth, remove from the engine, weld the rod to the plug base, then by screwing the stop in till it touches the piston youmay rock the piston back and forth as you back the stop out, you will be able to feel TDC. A long reach plug works the best for the project--Bob
