I have a 1985 Evinrude 50hp. 16ft Key largo center console. I took it out for my first run after buying the boat. I got out of the harbor, pushed the throttle, and planed out slowly, after about 30 seconds it lost power , acted like it was bogging down. I was about 500 yards from the harbor. I removed the plugs to check spark, good spark on top cyl, good spark on bottom, them noticed the bottom plug was dry, and the top was wet. I assumed the bottom carb had fouled in the high speed jet again. I didn't have the tool to remove the silencer, just the cover. It was getting late, and dark, so here's what I did. let me know what yall think.
I removed the primer line from the top carb (wet plug) and put a screw in it. Then ran the motor at about 1k rpm back to the harbor, hitting the primer solenoid (key) about every 5-10 seconds, and alternating with WD-40 into the carb for lube.
the trip back into the harbor lasted about 10 minutes. I will do a compression check this afternoon after work, and look into the plug holes to see if I've scratched the cylinders. What else should I do?
Boat History: got the boat a month ago, put the motor on, removed/cleaned the carbs, but apparently not good enough b/c one clogged before, after the poor cleaning. drained bowl, sprayed carb cleaner into high speed orifice and it ran good on the muffs. Just looking for opinions. Will compression tell me what I want to know?
Thanks
Adam
Thanks
Adam
