Did I get the right impeller replacement kit?
AChotrod
Just got back from the store with a new Mercury impeller repair kit. The guy at the counter looked up my SN and said this should be it, unless it has a bigfoot lower on it. As far as I know I do not have a bigfoot lower unit, but not 100% positive and would like a little reassurance.
Thanks in advance!
Motor SN is 0G252205
Part kit is Mercury Impeller replacement kit 47-19453T 2
I tried to link the part description since they dont sell the OEM part on here but the link wont work.
And here is a pic of the motor
carholme
Re: Did I get the right impeller replacement kit?
That s/n comes up as:
MERCURY - ( 60 H.P. (1995 ))
Serial No: 0G252205 Model No: 1060412RT
Parts list for model 1060412RT:
50/55/60 HP JET 45 - Mercury, Mercruiser, Force, etc. Parts Lookup
You have the right p/n for the standard gearbox which is a 1.64:1 ratio whereas the Bigfoot 2.3:1 and the Bigfoot has a 41/4": torpedo
The service manual you require for that engine is P/N: 90-817643R1. If you do not have it, see my message to you in Notifications at the top of this page.
Gerry
AChotrod
Thanks for the PM Gerry
The service manual I have is 90-817643-1 not sure if the R in yours makes any difference.
AChotrod
So been reading around and seems the bigfoot motors are not designed for my type of boat, but more for a pontoon or trolling boat. So Im pretty sure mine has a standard gear box.
AChotrod
Put it in worked great.
