I pulled my boat out of storage this weekend to clean it up, determined to get the gel-coat right this time. I have tried several of the "quick fix" ideas (like waxing, floor acrylic) and none of them had any staying power. This time I decided I was going to sand it down as far as I needed to and if it burned through so be it. I started with 100 grit on a machine, but ended up making more progress by hand. The 100 grit is what took the longest by a huge margin. Once the 100 grit knocked off the dead gel-coat I moved to 220 grit dry, then wet-sanded with 400, 600, 800, 1000 and finally 2000 and high speed machine buff with Maguire's heavy cut compound. I'm in about 18 hours and only have one side done- this is going to be a LOOOOOONG haul. I think it's going to be worth it in the end.
before:
After:
Justin
before:
After:
Justin
