mswalter2009
- Joined
- Jul 6, 2009
- 45
First off, thanks everyone for all of your expert knowledge you post to this site!!!
I just repowered my 18 cc with a 2008 Yamaha 90hp two stroke. Broke in the engine this weekend. The prop that was installed was a SS Michigan Wheel Apollo Series 13 1 / 4 by 17. This prop would hit the standard trim anode so the dealer either installed a different or ground down the stock tab to about 1 / 4 inch profile. Dealer says this a Yamaha part number called a ?Sport Tab?. Anyone seen this before? Don?t want to slam the dealer but I can?t find any such Yamaha Part.
The depth of this prop is such that the blades cross the anode tab mount about three quarters or more through the circular diameter of the mount. And, the tip of the blades are pretty close to the anode. A little more than a quarter inch. I just don?t see how any tab could be used. Is this prop just not designed for use with this engine?
From my knowledge (and this site) I should have a tab that counter acts the rotation of the prop in case the steering were to break. Is this correct?
Engine mounting ? With the engine trimmed full down the cav plate is below the hull about 1 / 2 inch or more. Shouldn?t this be 1 / 2 inch above?
Max rpm is 4500 and you can tell the boat is dragging. Lots of throttle left at 4000 to WOT but only not a lot of mph gain from 4000 to WOT. Bow seems to dig at WOT and you can?t adjust the trim to lift the bow very much before cavitation.
Performance ? The 13 ? by 17 prop seems to be the right size and pitch. Jumps on a plant, cruises nice at about 3800 to 4000. But after 4000 just seems to drag.
Boat ? 18 Privateer CC. (bay boat) Dry weight 1250. Very slight deadrise in the stern.
