Fishfearme1174
- Joined
- Dec 5, 2015
- 61
2004 Mercruiser 3.0 carb. Hard starting. Will only start cold with advanced throttle. Then will not maintain idle until ran in neutral with rpms above 2500 for about 6-7 mins. Then when attempting to propel forward, wants to die when going into gear but if you aggressively advance the throttle, there's a good chance it won't die and you can achieve normal cruising speed.
Very unreliable and especially a nuisance around the dock.
I've checked the shift cable and appears to be in specification. What else could this be?
