Evinrude Trouble
- Joined
- Sep 27, 2007
- 40
I have a J70LLCNB and i took it out for the first time today. I adjusted the idle like it was told earlier and it started right up and idled smoothly. I get past the no wake to try and see if i can get her to plane out and as soon as i try a hole shot the rpms jump like their suposed to and about 3 seconds later the motor sputters the RPMs slowly go down and the motor dies and has to be restarted. I tried easing the throttle forward and when i get about half way to WOT is when the engine starts to loose RPMs but if i pull throttle back to below half the rpms return to normal. I tried squeezing the primer bulb when the rpm's started going down and it did not make a difference. Any suggestions.
