Dies in reverse!
WakedOut
Alright, so alpha 1 gen 1 dies when shifted into reverse. Dropped lower and tested shifter. Shifts fine and watched the fork move to all positions when the shifter was moved. Made sure that all was in forward and reassembled. Cranked her up, forward was good, neutral very smooth, put into reverse and dies. What could it be? If it is shifting smooth and fine and moving the shifter when the lower is off could it still be the lower cable needs replacing? Does the shifter just need to be adjusted?
dubs283
Re: Dies in reverse!
you may get by with an adjustment but not for long - and you risk causing damage to the drive
its time to replace the lower shift cable
