Diesel additives for the winter
dingbat
It sounds like the first real winter is coming since we moved up to the farm. With that, I have a couple of diesel tractors that I need to ?winterize?. They will be used during the winter but not everyday. The manual says nothing about additives but advises to use #1 diesel in the winter. My 275-gallon fuel tank is full of #2 so running #1 in the winter isn?t an option.
Conditions: Daytime temps in the mid 40?s. Nights, mid-upper 20?s. We might get a couple of nights in the teens.
boat1010
Re: Diesel additives for the winter
I really don't think with temps in the range you are talking it is much of a deal.. I'm thinking that if it were in the 0 area you would start having problems with your diesel. Do they have heaters? If they do I don't think it would be necessary to leave them plugged in all the time, but maybe you could plug them in a few hours before ya tried to start them. Just MHO
matt167
Little Kerosene as anti-gel agent, plug them in on the really cold nights if they have block heaters and make sure batteries are up to snuff. Beyond that, just let them warm up before you run them hard
Bob_VT
Cut with Kerosene up to 8-10% and get a gallon of "Diesel 911" just in case you do freeze up a fuel system. I use that on the diesel tractors around here......... and we are a bit colder here in the mountains.
Fleetwin
Look at the labels before you use any additives. Do not add anything with alcohol in it. Alcohol is death to diesel engine injection components.
I agree with the above. Those temp's aren't that severe. Good clean (non Bio) #2 should cause you little to no issue.
WIMUSKY
The only additive I used in my tractor was Seafoam. However, I was using #1.......
The_Kid
Those temperatures shouldn't be a problem but if you want some added assurance you can use some PowerService in the white bottle. It will stop gelling down to -40. I've used their products for in my truck for 10 years.
DIESEL FUEL SUPPLEMENT+Cetane Boost
JRJ
At the temperatures you are talking, I wouldn't add anything. I am a block heater fan though. Have a smooth winter.
bassman284
Well, you might want to do some Googliing on "diesel gel temperature" or "winterized diesel" or other related topics. You will get varying opinions, but the preailing view seems to be that the modern Ultra Low Sulfur diesel gels at a much higher temperature than the high sulfur or low sulfur stuff that was prevalent 30 years ago when I was a trucker. I drove day trips in Iowa where sub 0? fF temps were a possibility throughout the winter and sub-20? could be fairly frequent in January. We refueled at the terminal and used a blend of about 50-50 #1 to #2 when the temps were likely to drop below 20? F. That wasn't always enough when it got really cold.
I haven't used any diesels since the early '80s, so I did some research and found out that the Ultra Low Sulfur (ULS) in use for the last 10-12 years or so has a much higher gel temperature than the stuff I was using in 1980. It can gel in the range of 20? to 25? so it's right in your ballpark. It can actually be a bigger problem in vehicles (or tractors) that sit for several days between uses. Remember, once it gels, your pretty much FUBAR until the ambient temperature rises well above the gel temp i.e., 45 to 50 degrees.
I would use an anti-gel additive in the tractors, make sure it gets mixed well and run the engine long enough to be sure the anti-gel has gotten to the injectors. It may not matter, but you really don't want to find out when it does.
Just too add, I wouldn't bother treating the 275 gal storage tank, just the fuel tanks on the tractors. In your borderline situation, that should be enough.
dingbat
Thanks. I put diesel fuel supplement in them last year and did not have problem. Wanted to make sure I was missing something.
