Diesel Fuel Water Separarion
sasto
Would there be a differance in condensation in a deisel tank vs. gas? Deisel returns fuel to the tank almost as much as she burns. The returning fuel is warmer than when it was picked up. Say she runs through 3/4 tank in a day. Is the condinsation rate higher or lower?
rbh
Re: Diesel Fuel Water Separarion
As you said If you feel the return line it should be really warm after traveling awhile, and I would open the fuel filter bowl petcock and drain the filter bowl each day.
45Auto
Warmer fuel tank = less condensation.
You get condensation when a cooler surface drops the temperature of the air in contact with it below the "dew point".
For instance, right now in New Orleans the dew point is 75 degrees (F). When I walk out of my air-conditioned office I have to take my glasses off because they instantly become covered with condensation since they're at 70 degrees from the A/C. If I warm them above 75 degrees before going out, they won't fog up.
Ned L
Thinking this through a couple of times finds me thinking that there may be a small bit less condensation in a gasoline tank. The actual condensation occurs on the exposed metal inside the tank (so it doesn't matter if there is gasoline or diesel fuel in the tank), however gasoline is more volatile, so the air space in a gas tank would have a lower % of water vapor containing atmospheric air as compared to a diesel tank (less volatile = less diesel vapor = more water vapor containing atmospheric air in the tank). That being said, once the condensation happens & the water droplets fall into the tank & settle to the bottom it can not evaporate out (because it is 'sealed in' by the fuel); so it doesn't matter that the diesel fuel & tank are warmed by the return line. --- Though as has been said, with the diesel tank being warmed while the engine is running, that is a time period during which condensation would not be occurring.
Of course maybe the rates of condensation are very different for a logical reason, this is just what I could rationalize.
Yes, diesel will have the water separators, so the recirculation of the diesel fuel will tend to filter out the water, but normally the pickup tube is above the bottom of the tank so you shouldn't be picking up the junk off the bottom to much, but that is different than which has less condensation.
rbh
I was more worried about what's coming out of the pump, not the boats tank.
sasto
That's a good point...even I can grasp.
